The rubber door seals on my Mitsubishi Lancer 2005 are lifting a bit. What type of adhesive should I use to stick them back down to the door?
This will work. http://www.permatex.com/products/Automotive/adhesives_sealants/specialty_adhesives/Permatex_Contact_Cement.htm Your local parts store will have this.
Just make sure both surfaces are clean before application.
Thanx much
