My 2002 Dodge Grand Caravan engine will not turn over.
It worked fine until this morning.
I tried to start the engine, but only got solenoid clicking on first try.
On second try, I got no solenoid clicking, but lights and everything indicate strong fully charged battery.
Tried jumper cables with no success.
Cleaned battery terminals…no change.
Did you remove/clean and replace wrench tight the cable connections at the starter end?
Check to ensure all ground connections are clean and tight. Some positive battery cables to starter have an in-line fusible link and yours MAY be burnt.
