Okay so Ill start off with the codes I got from auto zone.
-START AUTOZONE-
Definition
Crankshaft position sensor condition
explanation
The crankshaft position sensor signal is monitored for errors
probable cause
crank sensor defective
check connector and wiring to sensor
check trigger wheel for damage
-END AUTOZONE-
What Ive replaced so far
Ignition coil
Sparkplug wires/Ignition wires
Okay so the problem is that it will not rev about 2000 rpms the car has to shift through every gear @ 2000 rpms and it will not go above 60 mph when you hit that speed the engine starts to sputter
also on a cold start it will never start right away it turns over for at least 8-15 seconds before it will start
However after about 30 min of driving I can turn the car off start it again and the problem seems to go away
Note: after its warmed up and i turn it off and back on again it will start right away and wont turn over for 8-15 seconds like on a cold start
When I replaced the crankshaft position sensor it seemed to solve the problem it went away for about 2 weeks then came back?
Please help I DESPERATELY don’t want to take it to a shop
I have checked on the Fourms and have tried this solution
\-- http://community.cartalk.com/discussion/2281338/99-neon-fuel-pump-problem
In the Neon the fuel pump relay and horn relay are identical. Swap relays, put in a fresh fuse, and try to run. --\
\-- http://community.cartalk.com/discussion/2253592/relay
I have the same problem one day I went out to start it ant it started flashing FUSE it did that for several more days then i went out to start it it would not start and kept FLASHING FUSE on the odometer, so I Jumped it drove it around for 10 min parked it came back out 30 min later wouldnt start. Jumped it again same thing. then i drove it for about an hour and it hasnt flashed FUSE again except for one time a day ago on a cold start and havent seen it since --\
PLEASE HELP!!! Please ask for more info if anything is unclear
