Do I add AC oil
So I’m changing a couple O-rings that are under my quick disconnects going through the firewall on my truck. It must’ve had a slow leak. As of now I’m not going to add oil…
First am I wrong? I’m not changing any major component. I am using the vacuum pump to make sure all the leaks are gone once the O-rings are replaced.
Lastly besides changing the compressor, dryer accumulator, condenser or evaporator is there any other time you should add oil? Is there a guideline on when and when not to add oil?
I always add an ounce of oil when just replacing O-rings.
Manufactures specify how much oil to add per component change. Sometimes it’s written on instructions on component.
It usually goes like this,
Compressor=Refer to manufacturer for capacity.
Condenser=2 ounces
Evaporator=1 ounce
Receiver/dryer=1 ounce
Hose assembly=1 ounce
So even tho the original line is going back on, you would personally still add an ounce? Is there a place average Joe’s can see info like this incase I’m asked in the future?
Thanks for your help
No component change. Just 3 O-rings, all on the same fitting.
