I have a 1996 Dodge 1/2ton pick up. I can put my lights on bright and they burn ok, but when I dim them, they go out. I can raise my steering wheel up and it works ok on dim or bright. It is when I lower my steering wheel that it goes out on dim. Help.
Regards,
Freddy
Sounds like a frayed/broken wire or bad connection.
You’ll have to dismantle some or all of the steering column covers to expose the wiring, and do a continuity test from there on.
Someone one needs to start disassembling the wheel an all those wires, air bags etc. that are there. Likely they will be abel to see where the problem is and can correct it. It may take replacing the switch assembly however and that will call for some replacement parts.
Good Luck
