My friend has a 1998 Delta 88. Her AC/Heater blower stopped working, I assume it is a fuse problem… only I can’t find her fuse box to find out. Where is the fuse box on an 88?
I can’t say for sure but usually there is one on the drivers side of the dash (have to open the door to access it), and there are a bunch of fuses and relays under the rear seat on some. There are also some relays under the hood for horn, AC, etc. Why not just take a look at the owners manual and it will list the locations and the fuse numbers for each circuit.
Sometimes there is a cover that you remove where the driver’s door opens. The door covers it. Just an eighth of an inch away. Sometimes it’s under the hood labeled “electrical center”.
