My 1995.5 Audi S6 (similar to the A6 through much of the 90s, ending mostly in 95/96) has an INFRARED receiver between the pillars of the front and rear doors of each side of the car.
The key fob has an infrared LED on it that points the same direction as the key (protruding from the keyring).
Since I’ve taken the fob apart to clean it several times since I’ve owned the vehicle, and being an Electrical Engineering Tech., I can assure you that in this model of keyless entry there is NO evidence of any RF (radio frequency) transmitter in the device – it is INFRARED only — VERY similar to most television remotes.
I have seen 1996 and up Audi key remotes that are completely devoid of the infrared transmitter, and there are also similar audi models that look identical to mine (might be later 1995 cars, even) that to NOT have the infrared bubble receiver between the pillars of the doors (near the windows - right between them) — which means those cars are RF-only (not infrared).
Steps:
Dave needs to look at his key fob - is there an LED that points the same direction as the key metal? (in a dark room, if i hit the button, i can see a VERY faint dark red blip… your mileage may vary)
Dave needs to look at the side of his audi, between the front and rear doors, at the level where the window glass meets the metal of the door — midway up the doors in the pillar. If there’s a plastic “bubble” there, he’s got infrared keyless entry, like me. IF not, he’s got RF, like the majority of vehicles with keyless entry on the road today.
if it’s infrared:
You guys were correct on the bounce theory, which made me spit coffee i was laughing so much! but, it’s correct! bounce that beam!
if it’s rf:
Dave, do you have any elaborate dental work you’re not sharing with the brothers? Most people can afford to be a little intimate with these wonderful hosts!
-jre
