I have a 2003 Dodge Neon R/T. I replaced the stock throttle body with a larger one, and while doing so, I noticed that my cruise control cable is very tight. So much so that the throttle is slightly open at idle. It doesn’t even touch the screw on the throttle body that adjusts the idle. If I manually close the throttle, my idle drops from 1000rpm to about 700rpm. What do I do to loosen this cable so that the throttle is closed at idle?
Related topics
| Accelerator Cable | 5 | 859 | February 10, 2011 | |
| Ranger throttle stuck? | 4 | 995 | May 7, 2010 | |
| Sticky throttle | 4 | 654 | November 27, 2008 | |
| Idle Speed | 1 | 479 | August 20, 2010 | |
| 94 Corsica Cruise Control Servo Cable replacement? | 5 | 911 | January 23, 2008 |
