UPDATE ) Thanks TO EVERYONE WHO WROTE IN.OLD PROBLEM SOLVED ( BAD RELAY CONTACT IN STARTING CIRCUT )CHANGED OUT HARNESS.NEW PROBLEM CRUISE CONTROL , BLINKERS , AND KEY LOCK( ONCE KEY IN CYLINDER CAN NOT REMOVE WITHOUT MANUALLY DEACTIVATING )DO NOT WORK .4WAY FLASHERS ARE OK, all bulbs light inside and out, BRAKE LIGHTS WORK ,BACKUP LIGHTS WORK? Everything worked before going down. THANKS AGAIN FOR ANY HELP.
If you are saying that the CC, turn signals, and key lock don’t work I would make sure that the emergency flasher switch and turn signal flasher switch contacts are working correctly. Try cycly ing the emergency flasher switch a few times to see if that helps.
