Creaking noise when braking at low speeds
2015 Chevy Equinox, brakes make very loud creaking noise when coming at a stop sign/red light/park. Best way I can describe it as is the sound an old rocking chair makes on a wooden floor… I changed all pads and rotors months ago. Recently I took it to a trusted(at least I thought so) mechanic and he replaced a caliper and that seems to have fixed the issue for a day and it returned with a vengeance the next day. Brought it back, and he was certain it was a wheel bearing so I got that replaced but it didn’t stop the noise, although the wheel bearing was due for a change. He’s as lost about the issue as I am it seems…For what it’s worth, the sound seems to go away after it’s rained and come back when things have dried up.
Here’s a link of the sound I recorded, new here so I dunno if this will work… feedback would be much appreciated,
Brake noise can be very annoying and hard to trace down.
The first thing I ask when someone complains of brake noise is, were the brake pads/rotors properly embedded after the brake job?
https://ebcbrakes.com/articles/bedding-in/
I think I’d have a look at the brake rotor to see if it has a crack in it, check the pads, but the other thing is check all the bolts to make sure they are tight. After putting an axle in, I failed to use lock tite on the bolts and when they came loose got a similar knocking sound.
Some make/model’s brakes seem to squeak more than others. Bigger SUV’s are considerably squeakier than little econoboxes from my observation. Why? No idea. If the noise started after the rotor/pad replacement, the shop may not have installed all the required anti-squeak and anti-rattle shims. Or they just installed squeaky parts; i.e. not the oem parts purchased from the dealership.
If I had that problem and couldn’t live with the sound I’d disassemble the brakes and compare the parts installed vs what should be installed according to the shop manual. If that all looked correct then I’d take some 150 grit sandpaper and roughen the surface of the pads, soften the edges, and roughen the rotor surfaces to see if that makes a difference. If it did at least you’d know it was the brakes and not suspension components.
Squeaking during braking isn’t a common symptom for faulty wheel bearings btw.
Any resolution to this, because that is the exact sound mine is making and its driving me crazy!
Has anyone found out what causes this ? Mine is doing the same thing ! Driving me crazy
My 2012 equinox was making this exact sound. After multiple rotor replacements and beating my brain I found out mine was caused from a rust scale on the hub around the studs. It was preventing the rotor from sitting flat on the hub. I could see on the inside of the week old rotor after I took it back off where it was just sitting on the high points of the rust and not seating flat. And by not seating flat it was causing the rotor to “wobble” and intern would cause the noise when braking. I wire wheeled and cleaned the scale off the hub and it solved the issue. Hope this helps
I had the same issue/noise you are having on my Buick Regal 2014. I could only hear the noise when braking slowly and coming to a stop. My mechanic said it was the sway bar that needed lubrication. In my case it was the rear sway bar. That fix seemed to have worked and it doesn’t make the noise any more.
I had the exact same noise on my 2015 Chevrolet Spark as the car in this video and finally I got it fixed! It was the guide pins on the front passenger caliper, replaced the caliper and noise is finally gone it’s nice and quiet! Hope this helps anyone experiencing this noise because it’s very annoying trying to pinpoint the problem!
What was the fix to this? My car is making the same noise! 2014 equinox
See the problems and solutions above. Multiple issues cause the same sound with multiple solutions.
I dealt with this exact noise for years and it would always come back no matter what I did. Its finally gone and it took buying all OEM pads and rotors. 700 from Rock Auto and I paid a friend to change it all. No noise finally!
