Okay Gentlemen,
I’m trying all different avenues for my Mercury. I believe that a Power Brake Booster for a ‘63’ Galaxie will work for my ‘64’ Mercury Montclair.
Hard to get the info I need on the internet, cause I’m not sure exactly sure where to look.
Everytime I go to Google, I get so many ads for everything else but what I need.
Thanks so much.
I sometimes look up parts on the auto parts websites and compare part numbers for compatibility.
In this case, it shows the Galaxie and Montclair as having 2 vastly different part numbers so this means that a Galaxie would not be a direct fit and may take some adapting.
(Can’t blame you for considering it though; the Galaxie is under a 100 dollars and the Montclair is almost 500. Ouch.)
You might also check a copy of Hemmings Motor News. I think there are several vendors who run ads in there for rebuilding brake boosters.
Nope don’t think so. Looks like 62 and 63 are but not 64. Its $400 too. Go to Rockauto.com and plug in the vehicle information, click on brake and again on the booster. The parts will pop up. If you click on the part number, it will show the interchange information for cars using the same part. The Ford and the Merc are different part numbers.
