i have a civic and evry time im at a high rpm and shift it pulls to the right dont know what itis.also the engine sounds really heavy i need help thanks
Does it do this as you apply power? If so it could be torque stear and that is normal for a FWD.
Some torque steer is normal, but if its excessive and especially if it pulls to the right when you just let off the gas at high rpm (engine braking), you may have broken motor mounts.
Make that pulling to the left when engine braking.
