Citroen Engine in Peugeot 207
Hi all, recent bought a 2nd hand Peugeot 207 mplay, 07 plate, petrol.
The car drives like new, however, there’s a Citroen engine in it.
I’m assuming the original engine was replaced at some point?
I know they’re both French and began a joint venture at some point. Other than that Google isn’t very helpful with this one.
Also, if this isn’t the original engine, then I guess I’ll need to refer to Citroen for diagnostic codes and other repairs?
TIA.
Citroen merged with Peugeot in 1976, so it is entirely possible that the Citroen-branded engine in your Peugeot is a “normal” state of affairs. Because neither marque has been sold in The US–where 99% of our forum members reside–for several decades, it’s not likely that anyone here can provide specific technical advice regarding either of those marques.
Swapping in a different engine in a modern, computer controlled car like your 2007 is VERY difficult, I can’t think of why someone would go to all that trouble for a 207. So I agree, I bet it came that way.
Edit - if it is an engine with a Citroen label, it probably was a replacement for an identical Peugeot-labeled engine that was swapped out because of some major engine problem.
Google ‘2007 Peugeot 207 engine’ and look at the photos, I bet one of them matches your car.
The 207 was based on the Citroen C3, and it’s a reasonable expectation for the two cars to share a lot of gear, including the drive train. It’s the original engine.
Likely entirely normal. Back in the late 70s when Chrysler came out with the Omnis those cars had VW Rabbit engines in them. Even the valve covers were stamped VW.
And my parents had a late 70s Chevy with an Oldsmobile engine in it.
For a brief period of time, Chrysler was installing Peugeot engines in those cars when there was a shortfall in the supply of VW engines. Imagine the confusion regarding replacement parts for the few customers who got Peugeot engines…
Same engine used on various Citroen and Peugot models, C3 included
Suggest you pose this question on the Practical Classics forum; it tends to focus on European cars.
Me does not think a 2007 Peugeot 207 is a Classic vehicle.
But it’s practical.
2007 , what’s that, nearly 15 years old? Maybe not a classic yet, but certainly far from new, & rapidly approaching classic status.
If it was built at least 15yrs ago It could be imported into Canada
