I had a bad wobble in the front end thought it was a wheel bearing, a chirping noise started also. today I had the front passenger side wheel bearing replaced and check( by the trying to move the wheel while on the lift method) all the other wheels, only the one replaced seemed to be bad. I still have the chirping. it is very noticeable at 18 to 30 miles an hour, not effected by braking, or putting into neutral while moving. here is an audio file of the noise…http://www.mwidmock.com/page5.html I also had all 4 tires balanced, and rotated. could it be a tranny noise?
keith
2
Could be the AC belt or a U joint. Sounds more like the U joint
Related topics
| Chirping noise upon acceleration from stop coming from under truck bed | 9 | 8710 | April 20, 2016 | |
| Loud whine/grind from front right wheel | 7 | 1094 | December 26, 2010 | |
| Chirping noise | 2 | 560 | August 22, 2009 | |
| Chirp / squeaking - left front wheel | 8 | 3867 | June 8, 2023 | |
| 2015 Mazda CX-9 - Help with noise | 3 | 1783 | April 3, 2021 |
