- WHERE IS THE CHARCOAL CANISTER LOCATED IN A 2000 TOYOTA CAMRY V6, 3.0L,
2. WHAT DOES IT LOOK LIKE?
They look like a 2 pound coffee can, black plastic, and are USUALLY located down behind the passenger side headlight or down under the hood where the R/F fender meets the edge of the door. They will have at least one fairly large vacuum hose connecting them to the intake manifold…
Do you have a check engine light?
Before buying a canister check check valve in gas filler neck,vent lines from tank to canister for kinks or being plugged and gas cap. All of these can throw code that may make some think canister needs replaced.
Typically it is actually located underneath the cat back near the gas tank, and looks like a black plastic brick. Look under the driver’s side rear fender. It should have 2 or 3 vacuum lines attached to it.
