Car wont start
93 ont. ga 2.3 quad 4- both coils replaced, ign.module tested ok-4 times. crank pos.senser replaced, wiring ok, no spark help
Whenever this kind of thing happens the first thing that should be checked is to see if power is getting to the ignition system. Have you done that?
What sounds does it make when you try to start it? if there is clicking then its the battery, if there is no sound its the starter solenoid
