Let me tell you a story ‘bout my daughter’s 2008 Chrysler Sebring 2.4L…
We have owned the car since 2009. Recently the car has begun to start intermittently. Generally it starts normally. Other times it won’t. It can be driven for a month with no problem and then BAM! It won’t start. No dead battery sound, no clicking, no starter trying to engage NUTT’N!
AND… the brake pedal is firm! The brake pedal is firm and cannot be pushed down!
The car has been to the Dodge dealer several times. They have replaced the starter because a couple of teeth were missing, flashed the computer and replaced the alternator. The car started fine for a few days and then wouldn’t start again.
The Dodge boys kept the car for a week and of course, it started fine while they had it. One of the service managers told me to pull out a certain fuse to reset the computer. They also told me that they usually see these types of problems if the car was jump started wrong (the jumper cables were hooked up backwards I guess).
They even called the big boys in Detroit and they didn’t have an answer.
Can you help? Should I trade the car in and make it someone else’s problem?
