I have a 2001 impala and the trunk pops open after ive stopped and cut it off. this morning the interior lights started turning off and on the door locks engaged and disengaged and the door ajar light came on will pulling into the drive way and backing out. It stopped once i picked up some speed, but the security light came on. i need some help or maybe a good excorist.
Posted by: jwaters76
You could try an excorcist, but I would first try a new body control module (BCM) They are prone to causing a variety of weird electrical problems on this model car. It will require a GM dealer, or an exceptionaly well equipped independent shop, to program the BCM to operate correctly in your car, you cannot just plug it in and have it work correctly.
