Can I repair plastic flex hosing?
The flexible, somewhat delicate plastic tubing (not exactly sure what it is actually called)has broken on 2 different components while changing out a head gasket. It’s a 2016 buick encore, and one hose is the oil tube going from the turbo to the engine. The other, I think is an air intake line. Is there a decent way to reconnect the line together, or do I need to buy those 2 hoses? I’m not sure if more details are necessary to answer this question.
If you’re talking about the turbo oil return line, it’s not that expensive to replace.
https://www.google.com/search?client=firefox-b-1-d&sca_esv=564001347&q=2016+encore+turbo+oil+return+tube&tbm=shop&source=lnms&sa=X&ved=2ahUKEwimm9fV4p2BAxUeEDQIHXfPABcQ0pQJegQIDRAB&biw=1366&bih=579&dpr=1#spd=8911300905484243138
You’ll have to be more descriptive about the other line.
I looked it up and it is the PCV valve hose (or crankcase ventilation hose). It is also not terribly expensive and seems pretty easy to replace so i will end up just ordering both of those parts.
But these types of hosing seem to break very easily, and I am still curious if there is some sort of shrink seal stuff made for something like that since it is a low pressure, low heat system (or I would assume so based on the material).
There’s heat shrink tubing.
But sometimes it’s impossible to get it over the area to be repaired, and should be used as a temporary repair.
Generally it’s better to just go and replace the part rather than try to fix a broken one, if the price is low.
Think of the potential damage you could do do your car or engine trying to “save” a few bucks on a plastic hose.
