I have a 2009 5.4 f150 and doing a cam phasers Job. After removing the old phasers I find the timing marks are not lining up at all with the mark in the new phaser. The pin is seated in the back, and it fits right and straight. What did I do wrong? As long as the other side will match the same amount of jumped teeth dies it matter?
Related topics
| Cam shaft phasers | 9 | 1660 | October 14, 2008 | |
| 2AZFE cam issue | 29 | 6782 | September 19, 2020 | |
| Stuck trying to Change Timing Belt | 66 | 11940 | October 4, 2022 | |
| 1980's KZ550 Kawasaki Motorcycle Timing | 26 | 6973 | April 30, 2016 | |
| Two-timing mechanic? | 8 | 1980 | October 3, 2012 |
