Where is the cabin air filter in a 2000 Dodge Caravan?
I suggest you consult your owner’s manual. If that doesn’t work, ask your local Dodge dealer.
i don’t think the 2000 had a cabin air filter, at least not standard. If it does have one, it will be on the heater box, behind and under the dash on the passenger side.
Check the box for the aftermarket replacement filter or the aftermarket filter makers’ web sites, Fram, Wix,…
