jump in truck this morning.starting driving got to stop sign and hit brakes the brake pedal was hard as a rock so i’am guessing brake booster right or brake booster check valve.
depending on your vehicles set up (sorry, i’m not very familiar with Nissan’s,) this could be a vacuum leak or a p/s fluid leak (depending if your booster is vacuum operated or hydraulic.)
or, as you said- a booster or check valve.
That would be my guess too.
Try this: with the engine off, pump the brake pedal until it becomes hard. Then, while pressing on the brakes, start the engine. The pedal should sink a bit and get a softer feel. If it stays hard, your booster is bad or the check valve in the vacuum line is stuck closed.
