Brake pedal squeaks when released
My brake pedal squeaks when I release it, for the last two weeks. Does this mean I need maintenance, repair, or some oil?
More than likely the plastic bushing on which the brake pedal pivots is dirty/dry. Try spraying a silicone lubricant on the bushing to see if it gets rid of the squeak.
Um … would the bushing be inside the cabin, or under the hood?
Under the dash, above the brake pedal.
Thanks, Tester! I’ll find it and get somebody to help with it! :o)
+1 for Tester.
Customer: My brake pedal squeaks
Dealer: They ALL do that!
Customer: Why?
Dealer: So you know that your brake pedal hasn’t fallen off without you looking…
