Is there any way to reduce or eliminate brake dust on my aluminum wheels ?
Switch to ceramic brake pads, if available for your vehicle.
I switched to Ceramic pads but still get dust although lesser than semi-metallic. I don’t think you can get rid or eliminate them completely. It’s the residue from the pad rubbing against the rotor.
Agreed. You’ll reduce, not eliminate the dust. It will also be a lighter color, so you probably won’t notice it as much.
I own a Ford Crown Victoria. The front wheels came  equipped with OEM  brake dust protection shields that work quite well.
Xenophon A. Beake
