Blown Engine Possibly?
So I was driving down the road and all of a sudden I heard a pop and a lot of thinking around and inside the engine Bay. I slowed my truck down and it eventually just cut off. There were several codes that came up ranging from it being
  1. P 061A
  2. P06DA
  3. P22282
  4. P0521
I looked underneath and saw right above the oil panthers a hole in the side of the block where there’s oil that’s spattered all over the place. When I try to turn the car over it sounded like a bunch of rattling inside. I tried this once in that there was something wrong. Mind you I did this before I looked underneath and saw the hole. I’m assuming the block is fried. All these codes have to do with the internal control torque performance model and the engine and manifold oil pressure system. Also the oil engine control circuit which was stuck off. But I didn’t get any of these codes or alerts on my vehicle when I did the OBD2 scan. It just seemed to come out of nowhere. The only codes I kept getting were my catalytic converter. I’m assuming it’s a blown rod. Maybe even something with the oil pump possibly. I would assume anything with a hole blown through the side wall of the engine would result in catastrophic failure so is it salvageable or should I get a new engine?
Also there are no fault codes that are saying anything related to catastrophic failure for the engine and I still have coolant at the normal level and oil at normal level. And this is the next day so I’m wondering maybe even a head gasket blown??
Your engine is TOAST. Replacement is the only option.
The engine came apart inside and punched a hole in the block.
Time for a replacement engine or truck.
I agree your engine is done for
But can you please tell us what the year and model of your Ford truck?
Mileage and engine type would also help
Because if you tell us your truck is close to 30 years old, rusty and has 300k miles, someone may just advise you to get a new vehicle
However, if your truck is fairly young and in otherwise pristine condition, a replacement engine may be in order
Reading the trouble codes after you see a hole in the block is like straightening all the deck chairs on the Titanic.
Hey everyone, thanks for chiming in! So i took off the oil pan and looked inside. I think im pretty lucky lol. Only one of the rods broke. So far, things dont look to bad but i need to further inspect. The hole is very small, about the size of the end of a thumb tack; the part you hold.
My truck is a 2020 f150 2.7 w/ 100k miles. I keep my truck in pristine condition all changes very frequently every 3500 miles 4000 miles… The date on all fluids I keep a weekly maintenance log everything I’m pretty meticulous about taking care of it as there’s a lot of modifications done to it. It seems like just the lower block I may have to replace but everything doesn’t look that bad I’ll send a picture in today or tomorrow. I think this might be salvageable. But when the pictures get posted you guys tell me what you think. I feel like if the pressure switch hadn’t gone out then everything might be fine. Oddly enough there’s no codes for any catastrophic damage or anything like that coming up in the OBD scan. It’s just those codes. I did give a jump start to someone and I’m thinking that may have killed part of the battery because when I went to test the battery it only read 8.4 volts. I feel like it may have done something to the battery or alternator or some of the electrical so I’m running through all the fuses first and then I’m gonna go and see directly what the codes imply and try either replacing it or seeing if it still functions at all.
Only one rod ever breaks. Hard to imagine this as ‘pretty lucky’, the engine is shot.
So you think the whole engine is trash? Why not just replace the lower end of the engine? I’ve got an engine hoist. It’s only got a 100000 miles on the engine. The hole is small and can be patched.
Whatever caused that rod to break was likely the result of some other problem, like an oil starvation issue causing bearings to bind. Many other bearings could be damaged. Unless you know the actual cause, a good first guess (which is all I can do) is that you’ll be much better off with a replacement long block.
A problem like this is very rare these days, hardly ever hear of a rod letting go on a stock modern engine.
It’s not stock. I have just about 30k in mods.
Here’s more info on ‘throwing a rod’, typically major damage is done:
What Can Make a Motor Throw a Rod? | It Still Runs
A connecting rod putting a hole of any size in the side of a block is considered a catastrophic failure, and yes you are lucky, worst case it could have dumped oil under your tires and caused a wreck…
At the very least it will require a new short block, but a new long block would be better, cause if one rod bearing was starved from oil, who’s to say that other unforeseen damage has not occurred in the upper end of the engine…
Or just drop in a used engine…
what are these 30K in modifications you mentioned?
You have $30,000 in engine mods on a 2.7, 4 cylinder pickup truck engine? Please describe the mods.
Asking a 4 cylinder engine to power a full size pickup truck is a lot. I don’t think even an engine rebuilder would touch this one.
https://www.google.com/url?sa=i&url=https%3A%2F%2Fwww.kapwing.com%2Fexplore%2Fcaptain-picard-facepalm-meme-template&psig=AOvVaw29RSvklDfKNiSWLDt3P_k1&ust=1738752973647000&source=images&cd=vfe&opi=89978449&ved=0CBQQjRxqFwoTCNDhyNztqYsDFQAAAAAdAAAAABAE
Agree 100%.
What if the “30K in mods” is what caused your 4 year old engine to blow up?
It’s not worth trying to diagnose all the problems with your clearly blown engine; it will never run right.
Get yourself a new “un-modified” engine, or a new truck. Leave the engine as is, and chalk this up to an expensive learning experience.
And THAT is why the rod tried to make its exit!
The failure has blown crap throughout the inside of the engine. A teardown will likely show damaged bearing journals at the least. Problems not identifiable by visual inspection might include a bent crank, warped block, or damaged cylinder walls.
Replace it with a used engine or a new long block assembly from Ford. If you insist on keeping these $30K mods, add in another $3000 to replace the factory connecting rods and pistons with stronger aftermarket ones. And expect the next weak point to go BOOM sometime within another 100K miles!
You wanna play…ya gotta PAY!
Fellas, heres my mod list:
Oil cooler
Derale atomic cooler for trans
Mishimoto performance radiator
HPS upgraded hoses
Ford powerstorm forged pistons and rods upgrade
Melling upgraded oil pump
1000cc injectors
Hellcat fuel pump
Felpro MLS upgraded head gaskets
Mishimoto dual catch can
Big 3 wiring upgrade
Fuel pump -VMP Booster
AMS turbo inlet pipes
Turbo supersonic blowoff valve
Momentum GT 5R CAI
CVF hot and cold side pipes
CVF Titan V2 intercooler
180 SPD thermostat
CVF catted downpipes
Full slotted and dimpled racing big brake system - Wilwood
BellTech lowering kit 3" front and 5.5" in back (The best kit they have to offer)
BBK Bigger Throttle Body
Turbos r tocs
Custom 3" Dual exhaust - valvetronics - weld 3 piece
Performance raptor steering wheel w/ Wire harness from Grey Goose w/ LED shift extenders
Under Glow X w/ feet, sill, and, intercooler lights
Hood w/ vents
Smoked Ford emblems
Performance 1 step colder spark plugs and upgraded coil packs
Racing seats w/ 5pt harness - 2
Suncoast Stage 2 racing transmission
Custom full racing skid plate
MPT custom tunes: E85, E50, E30, and 93 octane
6 cylinder
And just how long did it last with all those engine mods?
For $30k I hope you got at least a couple months out of it.
Well, I think we can all agree WHY your engine let go
I hope you’re young and have a job that pays a LOT of money, because it’s going to be expensive to get this truck running and reliable again
If anything, you know what NOT to do going forward
And please tell us you didn’t buy this truck that was already modified
