Best way to retrieve bulb dropped in tail light housing without taking interior of car apart?
So I was replacing all the bulbs in my Highlander with LED. The bulb came out of the wiring connector during installation of the backup light and is now rattling around inside the housing.
Removing the entire housing would definitely get it out but this is a huge pain. I would have to tear quite a bit out of the interior to access the bolts or nuts holding the tail light housing in. There is an access panel you can remove to replace bulbs and it is barely enough to get your hand in to get them out. I sure hope these LEDs last because this ia a pain on a good day. It is really bad when you drop a bulb in the housing.
I tried a wire wrapped in gorilla tape and that didn’t work. It moved it around but couldn’t get it out. I am sure the sudden drop in temps overnight didn’t help with the stickiness of the tape either.
I had the best luck with a pickup tool like this one. I could grip it but not at the right angle to get it through the hole. I gave up when the tool finally broke, leaving one of its parts inside the housing as well.
I am also thinking I might just get another bulb and leave the other one just loose in the housing rather than take the entire back left of the car apart to get this out but hate leaving loose parts in places like this. Any suggestions besides complete removal of the housing or just leaving it and getting another bulb? I have another set on order.
