I pull fuel in DFW every day, 18-wheel fuel tanker. Something that almost every transportation company teaches is Tne Smith System. I’ve had to go through it so many times, I could probably be an instructor. Anyways, because of habits of drivers, sometimes I will edge closer to the zipper (dotted white line) to gain some attention, cause some distrust, etc to vehicles riding beside me, after turn signal on for awhile. It’s generally a bad idea to ride beside one of us, our tires are inflated to 120psi cold, and we build heat pretty fast in them. If they blow, you’re looking at a 65lb gator (tire tread carcass) flying out, and it’ll do some damage.
Because I can see into every car going by, the biggest problem I see is out of 100 drivers, maybe, and I men MAYBE, 5 aren’t looking at the phone. I know we all do it, but for extended time? Back to big rigs, sometimes we swerve on purpose, trying to get someone to pay attention. Another issue is the load. My tanker is baffled, and has compartments, but will still take me across the road on bumps, heaves etc. Until you ride in one, it’s hard to explain, but unless it’s one with a party hood (long nose one, older style, see kenworth w-900 or peterbilt 379 w/ extended hood) they make a smooth road feel like a washboard. Long noses are easier to work on, though, side note. There’s a lot to drivers doing stupid moves. But there are ways to avoid most problems on the road, and most of that is patience, a don’t care attitude, space, and more patience. Anymore, I kick back, maintain a steady speed with space in front, and it gets there when it gets there…
On a side note, when driving an 18 wheeler, the way the mirrors are set up, we can inches from an object, and it looks like 3 feet. I think this is what causes a lot of close calls, because inexperienced drivers don’t realize that, and think there’s more room than there is. The other reason is with usually 6 mirrors on it, drivers think, or mistakenly believe they can see more than they actually can. It’s a complacency thing, and although easily done, it’s usually when a big rig driver ends up filling out paperwork.
For those “Bahstin” drivers, you guys impress me. When I lived in the NE, Boston impressed me with the speed, close proximity, hostility, and wild maneuvers that didn’t result in 25,000 car pileups. I’ve since moved to TX…warmer
Another possible reason for it is different driving styles in different areas of the country. CA residents don’t use turn signals, NJ signals, then cut across at least 3 lanes, NY City guys signal AFTER they maneuver, the south goes 90mph minimum EVERYWHERE, and somewhere in between are the old school defensive drivers and new ones, who everybody is impatient with. Then there’s the “Me 1st” mentality that plagues the roads, which generally leads to these discussions… no answers, just more stories, I guess…
