Battery problems with my 2002 Camry
Dude are you high or what? You start a post stating your negative battery cable is missing and then you post a picture clearly showing your negative cable attached to the battery!
Why is there a sheet metal screw and a washer screwed into the air filter housing?
No negative battery cable and no place to attach one because the negative post is occupied with something.
Don’t drive impaired.
