Battery is Black
hi there,
just a quick one i am not the best with cars at all so i have had trouble starting my car the last week and i am waiting until Thursday for it to be repaired .this morning i went and looked at the battery and where the light shows whether the battery is green or red is completely black i have never seen mine like this however lights ignition and everything is coming on. does this mean i need a completely new battery? thanks
Hi! Please introduce your vehicle…
Make:
Model:
Model-Year:
Are you referring to a “light” (window to electrolyte) that is right on the battery itself and not one that is inside the car on the dashboard?
Also, how old do you suppose the battery is?
Is it the original?
Have you ever replaced it?
CSA
:evergreen_tree::sunglasses::evergreen_tree:
hi thanks for your reply .
its BMW, 320D 2007 and yeah the light i cant see 1 not even the red meaning it has low battery it was replaces about 5months ago but do not have the receipt sadly.thankyou
Can you describe the trouble when you had trouble starting it?
Did the car turn-over (engine cranking sound)… rrrr…rrrr…rrrr… ,but fail to start and run?
Or
Did it just click and not turn-over (crank) or not even click?
CSA
hi, i love the use of onomatopoeia haha. But yeah i went in to a shop[ i saw i left my headlightts on when i was paying for my things then i went to start the car and it didnt even try to turn over , ignition andlights all came on but the car itself didnt turn over not one bit
Not necessarily. It’s possible, but there could be a problem involving the car’s charging system which is responsible for keeping the battery charged, a problem with a wire or cable, or all of that is working okay, but something else is draining the battery.
A light (like an interior light, light in a glove compartment or trunk), or other electrical device left on by accident or by a fault in its system can drain the battery. This is called a parasitic draw.
Your mechanic should check for any of these possibilities to assure that the correct solution is performed.
CSA
okay perfect thankyou very mucch!
Pow! Boom!
You just took me back to my Linguistics 176 or 177 class!
CSA
[quote=“Morgen_Porter, post:3, topic:150763”]
it was replaces about 5months ago but do not have the receipt sadly. [/quote]
I know from experience that Auto Zone retains an electronic record of your battery purchase, and it is possible that other retailers do, as well. So, if the battery does need to be replaced, it is possible that your lack of a receipt won’t prevent you from getting a new one, gratis.
Where did you purchase the battery?
