Car did not start (2007 Honda CRV).
Car got new starter.
Later, car did not start again, sounded different, no clicking…
Mechanic did a systems check with the machine with a fresh battery. Systems check came back OK but battery drained.
Any ideas??
If you are sure the battery was low on charge instead of having a problem with power not getting to the ignition and starter system then you need to check for a current drain using an ammeter. I’m not sure what kind of testing was done with the ‘systems check’.
