Have a 2014 Toyota Corolla where the remote access controls have become inoperative. At first you would have to unlock the car manually and then the controls would work. Now, however, they do not work at any time. The car came with two. I have switched the batteries in both and neither works. Any suggestion would be appreciated.
Is it possible for you to provide a bit more detail?
k ?
The vehicle does not respond to the keyless entry transmitters, do the power door locks operate from the door lock switches?
The locks operate manually fine. You hit the switch all doors respond correctly.
You need to be more clear. First you said the key fob did not work after you replaced the batteries and then you said the doors respond correctly after you hit the “switch”???
