AudiS5Cabrio Remote Won’t open or close top
The remote key fob operation of my cabriolet top abruptly stopped working. No settings were changed. It just stopped. The one button windows down stopped too (via remote). I tried my second remote. Same result. Any troubleshooting tips or ideas why this has happened? Thanks
If the second one had not also failed, I’d say batteries. In this case I say whatever electronic module receives the FOB signal has failed or the antenna has failed.
It is going to take a pro-level scanner to find the problem. Find a VAG specialist for this.
This will probably take a specialist to resolve. Did the car’s battery charge run low just before this occurred? If so, it might just require a reset procedure of some sort.
If the problem is in the s5’s rf receiver hardware, that will likely require a replacement part. When my rf-operated garage door opener failed to respond to the remote the problem turned out to be one the rf receiver’s tuner capacitors had changed value w/age.
Check the auto window setting in the center display to be sure auto windows (and top) are enabled.
Shown near the end of this video:
How To: Open/Close 18’ Audi A5 Cab roof with Key Fob! (Secret OEM Feature)
