Another question about my wife's haunted Escape
#1
Car-part.com shows SEVERAL parts labled “computer box, non-engine” for a 2007 with different part numbers. Is that the one I need? If it is, it would appear that I’ll have to remove mine in order to see the right part number. There several different ones for any given year.
If I can find a smart junction box from a salvage yard, will it have to be flashed to the car in or is it simply “plug and play”? I’m hoping.
Here’s the earlier discussion.
http://community.cartalk.com/discussion/2306372/2007-ford-escape-interior-lights-have-a-mind-of-their-own-on-off-randomly/p1
#2
When replacing the SJB, the configuration from the old SJB must be up-loaded to a factory scan tool. Once the new SJB is installed, then the configuration of the old SJB is down-loaded to the new SJB.
I should also mention that the SJB is an integral part of the TPMS.
So it’s not going to be a plug-and-play affair.
Thanks Tester for not letting me make a big mistake. It looks like it’s a job for a pro with the right kind of computer/scanner equipment. Unfortunately that’s not me.
