Air filter replacement
How do you change an air filter on a 2000 Dodge Caravan?
hold on a minute, i’ll go outside and look.
the last time i did it it was the two steel clips on the back and the side on the plastic “box” on the passenger side of the engine. the plastic cover (once loosened) is shifted sideways so the two tabs can be disengaged and the lid is lifted off.
one clip is right next to the washer fluid fill, the other is behind the box, on the back side.
once you get the two clips snapped off, wiggle the cover up and towards the middle of the car. once the two tabs come free you can lift the cover up to change out the filter.
Bingo!
