a fog came out of the vents with the a.c. on. Any ideas.Heater core? A.C. freon?
First check would be making sure the drain tube for ac is working. An easy fix is by blowing out the drain tube.
thanks, How do I do that?
Have you found the drain tube? It is usually close to where the passenger puts their feet. Some you can get to from above others below. Use some garden string trimmer line or compressed air to free it up. Be careful as you can cause damage if you are not.
thanks, I’ll give it a try when it stops raining outside
