Air Conditioner
During this heat wave in Georgia - I have water coming in from inder the dash and dripping on the floor board. How do I stop it?
Most likely you have a clogged drain line from the AC evaporator. This line is designed to drain under the car. You can usually unplug it with something like weed-wacker line that will not damage the evaporator. Look for a small drain hose under the center of the car.
