i have a 2005 dodge caravan the air bag light is on checked the codes it was left saet belt retractor replaced the seat belt female end the light is still on the horn works what else could be wrong? thanks
The retractor is hidden part that the seat belt reels up on, not the buckle. You have to buy the retractor and the whole seatbelt as an assembly. If you don’t know what you are doing, then you should get someone else to do it. There are explosives in the retractor, usually. (In an accident the explosives fire to pull the seat belt tight on you.)
