After air filter change 2004 Honda Pilot mileage reduced by 50%
After air filter change our 2004 Honda Pilot mileage was reduced by 50% (got about 11 mpg on interstate and we used to get 24 mpg). I checked tire pressure and they were low, so I inflated them. I have a code reader, and the car is showing no error codes.
I am looking for advice/ideas.
If you replaced the air filter the air box cover had to be removed.
Check to see if a sensor got unplugged or if an air leak was created between the air box and the throttle body.
How are you calculating your gas mileage???
