What do you use to clear mold spores? Other than Lysol. Thanks!
It depends a lot on the surface the mold is on and the local conditions. In some cases a good dose of Ozone will do a lot. Soap and water often work well.
Eliminate moisture and a food supply for the mold and it will no longer be a problem.
You will never totally eliminate all the mold and if the conditions return, so will the mold.
Good Luck
Call local auto parts stores and find out if any sell this product. http://www.carfood.com/bgfridsysdis.html
