abs light came on when I got home turned off engine something is still running found vac hose big hole .replaced still doing same
You’re probably going to have to go to a shop that has a scan tool that can read abs diagnostic codes. If you feel lucky and want to try something yourself first, make sure the big thick hose between the intake manifold and the brake power booster is connected at both ends, and that a vacuum can be maintained on the power booster. Unlikely to be that, but easy enough to do probably, so worth a try. Usually abs warning light problems reported here are due to faulty or disconnected wheel speed sensors. Check the brake fluid level of course.
