I have an 1995 Chevy Lumina. It uses a OBD1 port and it doesn’t have the pin to see the codes flashing on the dash. I need a code scanner that will read ABS codes. Who manufactures a scanner that reads the ABS codes?
What ABS codes?? There are no such codes, especially in 1995…
That’s funny. My 1994 had ABS codes. I suspect that his 1995 does too. The dealer scan tools can get to them. I’m sure some aftermarket tools can to, but I don’t know which ones specifically for him.
Didn’t the ABS system have a separate diagnostic connector from the OBD system back then?
Yep.
