You can’t count the flashes, separated by pauses and get some digits?
The pauses between fault codes are just a bit longer than the pauses between the individual digits that make up the codes.
An 01 should be OBD2. You might have to find somebody with a proper scanner/reader to pull the ABS/SRS (B/C body) codes for you. That won’t happen at an auto parts store where they generally can only pull engine/trans (P) codes.
As an owner of older vehicles I can tell you that some of these problems become more elusive with vehicle age.
CSA
Well, abs light came on after 50 ft.
you can jump pin 4 and 9 on Hondas and get code flashes.
says code 14 which is LF sensor short.
which is where wheel bearing was destroyed.
this accord uses tone ring on cv axle
sensor picks up tone pulses from axle ring
will try new speed sensor
If you have a lab o’scope, it’s probably possible to use it to see if you are getting the same type of sensor pulses from that wheel that you get from other wheels, when you rotate the wheels manually. Might be able to get some idea even just using a dvm in ac mode.
Sometimes a bad wheel bearing will trigger an abs light. Any unusual noise from that wheel?
