Inside under the glove box the duct work leaks water from the seams.tape,glue,caulk what can fix this???
I would suggest two likely causes. First, if the humidity is high it could be condensation and there is not much you can do about that other than switching from recirculate to fresh air or it may be a blocked drain. For that get some string trimmer line and and feed it up the drain which is usually under the car in front of where the passanger puts their feet.
ok I put a vaccum tube as far as it would go into the drip tube seams to be clear and drains when the truck is stoped or shut off.could be the humidity like you said thanks for the advice…tom
