Car will not start at times. When this happens you can start the car manually by shorting terminals on the solenoid. At least I think that is what it is. Mounts on the right side of the engine compartment. AAA showed me how. Safety switch that prevents starting unless car is in park has been replaced. Used test lamp to determine that when the car does not start there is no voltage coming in to the solenoid. Looking for ideas on what to try next.
Related topics
| Intermittently failing to start | 3 | 457 | August 30, 2019 | |
| 97 Tahoe Intermittently Not Starting | 4 | 746 | November 4, 2015 | |
| Start Problems with 2003 Ford Taurus | 7 | 12289 | September 12, 2016 | |
| 91 Four Taurus keeps trying to start | 5 | 919 | September 30, 2012 | |
| 95 ford Taurus not starting, no noise | 4 | 491 | May 13, 2018 |
