How can I use the climate control center to check out a fault in the rear left wheel sensor circuit and other circuits–not necessarly the wheel sensor
The climate control system can be used to access codes but I’m not sure it can access the ABS codes.
To access the diagnostics you push and hold the OFF and WARMER buttons until the dash enters the diagnostic mode. It is going to display any current codes and at that time will be able to see if any ABS codes are stored. This is the best I can do at this time, I don’t have the detailed directions, without the directions it’s just about impossible to tell you how to access the rest of the diagnostic modes.
This should at least get you into the diagnostics and find any current codes
