I have a 95 Nissan pickup 3.0 4x4 this thing runs ruff not much power idols ok but when u put in gear it gets worse. It shifts kind hard to reves to like 4000 before it will shift. Idols about 800 and like 500 in gear
3.0 v6 4x4 vg30
3.0 v6 4x4 vg30
On my 95 Nissan pickup, a bad Mass Air Flow sensor caused the engine to fall on its face.
https://www.rockauto.com/en/moreinfo.php?pk=3020397&cc=1212141&jsn=450
Did u get a code when it went out only code I got is 55 no malfunction.
The shop said everything is pointing to computer ecm
No code. No Check Engine light.
But then, this vehicle is OBDI. Not OBDII
It sounds like there’s two problems, one is the engine performance, and the other is the transmission is slipping. I wouldn’t chalk either of those up to a bad computer as my first guess. For engine here’s where I would start. For the transmission, first get the engine working correctly and report back.
If problem remains …
