Need to replace front left cv shaft.  A crack in the ABS sensing dial is sending a false signal.  The ABS thinks you’re sliding and comes on slightly.  Can I leave this go without harm, or disconnect?  Do I need to replace pads & rotors at the same time?
 altoona kid
I would disconnect the ABS sensor immediately. If the ABS has been applying the brakes unevenly, I would replace the pads, and possibly the rotors.
