driver side window stopped working in my 91 honda accord ex 4dr sedan. i dont know if its the track or what. but when i try to roll it up it goes all sideways. i cant really see in there and dont know what to do. how do i fix it?
Take the door panel off and you will see what the problem is.
i took off the door panel and i stil cant really see. the access wholes are really small.
Look to see if you can see how the window opener attaches to the glass. Where it attaches to the window may be a channel that is suppose to be glued to the window. sometimes these come loose from a window causeing your problem. Not sure if this is how yours is attached. It helps to watch the window from the inside with door panel off as you try to roll it down.
