89 Chev Celebrity--License Plate Bulbs
In my 89 Chev Celebrity, how do I get at the license plate bulbs to change them?! Thanks for your help.
Do you have an Owner’s Manual?
If you do, I can pretty well assure you that there should be directions in that little book.
If not, a visit to your local auto parts store is probably in order.
If you buy the bulbs from them, their employees will probably be willing to install them for you.
Aren’t There Screws Holding The Lenses Over The Bulbs?
Once a lens is removed and you have the new bulb, I think you’ll see that the bulbs just pull out and push in.
CSA
But how do I remove the lens? There are no screws holding the lenses over the bulbs. The Owner’s Manual doesn’t handle this.
