I used the timing mark on the crankshaft damper to find TDC by turning the engine by hand until the mark pointed at zero,I also used a straw in the #1 plug to determine the highest piston,the zero mark and the piston check out fine but I only see one timing mark in the middle,and the rotor points to the #5 plug.
